I finally got a semi decent pair of head phones to use with my Hercules, up until this point I have just been doing everything on the fly.. Yes, it sounds like crap ;)
Setup : PC
Windows 7
8gb ram
x4 @ 3.20 Ghz
AMD Radeon HD 6950
I have my video card as my main sound driver via hdmi(meaning pc sound comes through tv speakers) and have a cheapo surround sound, 5.1 to be exact. I can plug each channel in via 3 audio cables(front, back, middle) and it also has an adapter to take the red and white audio outputs.
So my two questions/problems are as follows : I can get the sound to play out of the TV via usb, I can get the sound to come out of the surround via 1&2 outputs on the back to surround adapter, I can manage to get sound in my head phones, while I am only using the the Hercules sound card (headphones in headphone jack, surround sound in 1 & 2.), and I can manage to get sound just through my head phones.
What I want to do is get sound through my TV and my headphones instead of surround, so I can practice at night without having to use the 5 speakers + woofer. It really helps me to be able to hear both the music I am playing and the music I am putting out instead of doing it all in my head phones.
I have tried multiple settings in the config and have found posts via google that says use aiso mode but I cannot get it to pump through my speakers and phones. Am I missing something somewhere?
My other problem is that when I cue up a track when I have my headphones + surround sound playing together, the cue plays out of the surround sound and not just my headphones. So when I am trying to do something you can hear, "beat beat beat oddbeats beat beat oddbeats." This is horrible D: It is just like doing it without headphones.. If anyone can help me get my audio set up so I can start apply all the reading I have been doing, I would REALLY appreciate it.
Setup : PC
Windows 7
8gb ram
x4 @ 3.20 Ghz
AMD Radeon HD 6950
geposted Tue 10 Apr 12 @ 1:55 pm
This is driving me mad. The cue also shows up on my recording.
geposted Wed 11 Apr 12 @ 11:06 am
The more components you are trying to have working together, the more likely you are to get problems.
Now, you've bought the 4-Mx which incorporates an audio interface tailored for DJ work (i.e. make your life easier), and yet you are jumping through hoops to get this thing going.
I would suggest the following configuration:
a) Set the 4-Mx as your audio interface in Virtual DJ
Input : Line In
Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
Soundcard: DJ Console 4-mx
b) make your audio connections
- Your headphones to either of the appropriate connector on the 4-mx
- Output 1-2 RCA to an analog input on your TV (where you would normally connect the audio out of a DVD player or gaming console).
Input : Line In
geposted Wed 11 Apr 12 @ 2:18 pm
