I am using VDJ 7.0.5b PRO (b380)
Load a song to Deck 1, hit play, the crossfader to the left. - no sound.
bring the crossfader to the right. - sound
Load a song to Deck 2, hit plat, the crossfader to the right. - no sound
bring the crossfader to the left/ - sound
tried solution with link video crossfader - no success
Help...
Help...
geposted Sat 14 Apr 12 @ 11:22 pm
Solution I found so far:
Backup database, skins, etc.
uninstall vdj along with settings & database, then reinstall.
geposted Sun 15 Apr 12 @ 8:54 am
This may be because your sound settings were not configured correctly (The outputs of your sound card in CONFIG -> Sound Setup were reversed?)
Or if you are using a custom skin with a crossfader hamster switch, you may have accidentally activated this. You can also toggle this by mapping a keyboard shortcut or MIDI controller button to the following action: crossfader_hamster
geposted Tue 17 Apr 12 @ 6:05 am
