i have search the forums before posting this and have found no answers to this problem.
over the past week i have been doing live broadcasts to different third party hosts. at leads once a session the Virtual dj programme will freeze uo then close.
this is a massive bugg that need addressing.
i will test the windows version in the week. it maybe a mac issue?
ANY ANSWER PLEASE TO THIS ISSIUE WOULD BE GREAT
geposted Wed 18 Apr 12 @ 2:52 am
What is your setup? what controller you used? if you used controllers and re-routed the line out of the controller to connect it to the mic input of the mac and you assigned the built-in input in the soundcard settin in the VDJ config to broadcast, sometimes it will crash to some controller and that is not VDJ problem that is because of the limited soundcard support for mac, you have to select soundcard/controller that is fully supported by mac. Most controller soundcard are on ASIO and MAC doesn't have that natively. Try to update the soundcard/controler driver/firmware for mac.
geposted Thu 19 Apr 12 @ 4:08 am
