Forum: VirtualDJ Skins
Topic: eject button not working
my eject button on my mixlab skin is not working on either deck......HELP!!!
geposted Fri 20 Apr 12 @ 8:32 am
When did it stop working?
Have you changed anything?
Have you rebooted and tried again?
Keith
Not the end of the world, just load another track on the deck you want to use, don't know why you need one to be honest.
it stopped working about a couple weeks ago. Rebooting and/or re-downloading has not worked either.
No - its not the end of the world but I just like to have it work. thanks for being honest!
any other thoughts.....
Go to the skins folder in documents > VirtualDJ and delete the Mixlab zip file
Restart VDJ which will force use of the default skin
Re-download Mixlab and reinstall
See if that works!
Keith
I am having the same problem with this skin (which happens to be my fav unfortunately). I closed VDJ, deleted the zip file and when I restarted VDJ it came up with the error that it cannot find the skin file, please reinstall the app.
So I went on without restarting VDJ, reloaded the skin, and restarted VDJ. This did not solve the problem.
Any more ideas?
How about following what the message told you ? ;)
Re installing the software will not harm your database, settings etc, even though a backup of the Documents/VirtualDJ folder is always a good tip.
Not sure what went wrong. Maybe you had renamed/resized the skin file in the past or putted in the wrong folder ?
You can also use the Registry Tool https://virtualdj.com/addons/2170/Registry_Tool.html which might help you to understand what skin the software is looking for.
I did do what the message told me. I came back here and downloaded the skin and reinstalled it to no avail, and yes I have recently reloaded VDJ and I had the problem before that too.
Sorry for beating this one to death but I do have new info on the problem. One thing I realized is that I'm talking about the unload feature from looking at the xml file.
I uninstalled VDJ 7 by way of Windows Remove Programs in the control panel and reinstalled to the latest version this evening and that did not help.
I have downloaded MixLab 3.1 again and that did not do the trick.
I also downloaded MixLab 3.1 Ritch version and that has the unload feature working but the screen is now squished.
I went through and removed any VST plugins, sound effects and visual stuff that I have added from the VDJ site.
I have started using one of the stock skins with 2 decks. They are useful just not what I'm used to after a couple years with the same skin.
