I recently purchased a numark n4 and can not figure out how to configure virtual dj le with the hardware. The crossfader does not work or fade between the two sides and I can not figure out how to set up that the main mix goes out the RCA output and the headphone mix goes out the headphone jack on the front of the piece. I\'m completely lost here and have tried every combination of inputs and outputs to no avail, help please!
geposted Sat 21 Apr 12 @ 1:36 am
And this is another reason I'm afraid to get an N4
geposted Sat 21 Apr 12 @ 3:27 am
I just bought one (I have a Macbook Pro with VDJ Pro) I plugged it in selected headphone 4 card sound card hit the N4 dropdown and everything works great.
Dave
Dave
geposted Mon 23 Apr 12 @ 4:38 pm
Except for last night ! my pitch control did not work on either side running VDJ Pro works fine with LE and DJ Intro! Crazy!! I will try the mapper Cstoll has provided maybe that will help!
geposted Sat 28 Apr 12 @ 1:58 pm
I got great help from VDJ today that corrected my pitch control issue!! I love this software and the support and updates!!
geposted Mon 30 Apr 12 @ 9:34 pm
I have the exact same problem...I tried every combo and it doesn't work. I used to have a MixTrack Pro and it had a "Numark" Drop down tab in the Sound Card tab and everything worked great, I wish the same happened with the N4. Can someone tell me if it is the software or the Hardware or my computer...I have a HP Pavilion dv6000.
geposted Sun 30 Sep 12 @ 1:22 am
