Hi, looking for a little help.
Is it possible to set a slight adjustable delay to the video feed (or in some cases advance it) in relation to the audio.
The reason i ask is that i have experience of many setups, from my own mobile setup, clubs and pubs, in many cases all the sound goes through sound processors, limiters, EQ's and all sorts of boxes of tricks that create a slight delay from what you have in your headphones / playing.
More often than not video goes directly to a TV / projector, or a switcher unit, and has little to no delay and creates the effect of the sound and video being out of sync, especially noticable on karaoke where the lyrics highlighting appears to cue the singer in ahead of time, and generally look a bit odd.
Sorry if this this is already covered anywhere else, but I am new to these forums and couldn't find anything after looking around first.
geposted Mon 23 Apr 12 @ 7:23 pm
Its a very interesting issue... looked out there and found this. Hope it helps.
geposted Mon 23 Apr 12 @ 8:03 pm
Thanks speedy,
not exactly what im looking for but stilll a very good spot.
Ideally I was hoping for a software adjustment that is there in other dedicated video based or karaoke software (such as MTU hoster) just to slightly tweak the relative frame of the video being displayed to correct out of sync sound/video.
For example 2 minutes into a song a 0.25 second delay would show:
sound @ 2:00:00.
video frame from 1:59:75.
So they appear to be in 'sync' after the slight delay from audio racks, etc.
Is this maybe a feature that could be included in VDJ, or there somewhere I havent found. Or even adjustable through nVidea video driver for only the second monitor?
sound @ 2:00:00.
geposted Fri 27 Apr 12 @ 10:57 am
