Topic: VDJ7 + Hercules 4-Mx = no mic
Hercules 4-Mx mic input and button works when VDJ is not running. When I start VDJ the button that turns on the mic stops working. I also have a RMX and the mic button works as it should when VDJ is running. This behavior happens on both my gigging laptop and my desktop.
Everything else works fine on the 4-Mx. This is not much of a problem for me since i have a mic mixer in my rack but i want it to work when I gig at a place i do not bring my rack along and there is no mixer around.
Setup
Laptop
Core 2 duo
4gb ram
win 7 64 bit
Desktop
Core 2 Quad
8gb ram
Win 8 preview (yes it runs VDJ well)
Thanks for your help.
geposted Tue 24 Apr 12 @ 9:39 am
hey DAZ , nice avatar , looks like an XARA
if i had the 4mx i'd give it a spin and get back to you.....
have you tried searching at the Hercules forum ? give that a shot ...
VDJ disables the Talk Over function of the 4-Mx in order to use the microphone as an external source and recording.
In order to use the mic, be sure to set the audio configuration as follows:
- Input : Microphone
- Output(s): Headphone
-Soundcard: DJ Console 4-Mx
Doing so, when pressing the Mic On/Off button, Deck A will switch to external source and the microphone will come thru.
speaking of the Hercules forum .......
Thanks to the VDJ community for your help. The suggestion worked.
Thank you DJ Phatso. Your solution helped me as well!! =D
I was experiencing the same issue with the mic. now it works but what causes the setting to change?
