I am just starting to DJ however I can't seem to get my headphone and speakers to work properly with out having them coming out choppy. I have installed Virtual DJ Pro along with Numark Dj iO. I also plugged in the rca cables to dj io and my headphone. However when I start to play a track it comes out choppy on both ends.
Someone help me with this please.
geposted Wed 25 Apr 12 @ 10:52 am
Are you using a lousy RCA cable? I believe if the dj io has no problem, then it's the problem with the cable or your headphone plug.
geposted Wed 25 Apr 12 @ 11:32 am
I just bought the cables and the headphones. This was also happening with the speakers I previously had and headphones and I thought it was those problems so I had them replaced. Same thing.
geposted Wed 25 Apr 12 @ 11:40 am
then i believe is the problem with the soundcard, check with your manufacturer? is your dj io ware up to date?
geposted Wed 25 Apr 12 @ 11:41 am
The interface that I bought is this one : http://www.skratchworx.com/newspage.php4?p=archive&fn_mode=comments&fn_id=1758
I re-installed it from Numark's website because the CD provided gave me an "error" upon almost completing. So I looked it up online and downloaded the software through their site which installed it all the day and required for my laptop to restart.
Could it be that my laptop is too slow? I have an HP Pavilion 2000.
geposted Wed 25 Apr 12 @ 11:50 am
That interface comes with VDJ home, not the pro version you have stated.
Please see here to optimise your PC for performance issues: https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Keith
Keith
geposted Wed 25 Apr 12 @ 11:57 am
So that would fix my problem by downloading VDJ Home?
geposted Wed 25 Apr 12 @ 12:02 pm
Depends where you got the Pro version from. If it is legitimate please register your serial on this site and download the latest version. Otherways download the home free version here: https://virtualdj.com/products/homefree.html
Your PC may still need to be optimised to get rid of the skipping etc.
Keith
Keith
geposted Wed 25 Apr 12 @ 12:26 pm
VirtualDJ Home FREE does not support using multi-channel external sound cards such as Numark DJIO.
To use this card, you will need to purchase the either VirtualDJ Basic or the full Professional (Pro is required if you also need to use MIDI controllers, full-screen video, etc.): https://virtualdj.com/products/comparison.html
If you like VirtualDJ, please support the software and its future development by purchasing it, or register your Pro serial number to your profile page if you have already purchased: https://virtualdj.com/users/edit.html
As above, if you are getting stuttering, popping, etc. then you have performance issues with your computer. Please see the above page for common causes and their solutions: https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Wed 25 Apr 12 @ 12:32 pm
