I am using two timecoded vinyls and all of a sudden VDJ wont loop. It shows the loop but when it gets to the part where it should be looping back it just keeps playing. It works fine without the timecodes it is only when I am using the two timecodes.... help pleasseeeeee
geposted Wed 25 Apr 12 @ 2:08 pm
This may be because you are using timecode in absolute mode. This always plays the song exactly synchronised to the position on the timecode record or CD.
In this mode, loops, cue points, etc. within VirtualDJ cannot be used.
For this, you need to use smart (The default) or relative mode.
You will also need to purchase the full VirtualDJ Professional to be able to use timecode. If you like VirtualDJ, please support the software and its future development. The RMX console registered to your profile entitles you to a significant discount, which you can take advantage of by going to https://virtualdj.com/buy/
geposted Wed 25 Apr 12 @ 5:47 pm
