so... finally using a 8-channel soundcard with VDJ Pro. Its great to be playing in stereo instead of mono again. I don't know why I was so resistant to it. Was using a Behringer. Now, I'm back to using a Gigaport AG.
Need help with the "performances" settings for the gigaport. what are the "best" settings for this tab?
.I want to make sure the loops sound clean, and the latency is good. I don't scratch. And, I didn't install those ASIO drivers. Just straight plug in into a Win 7 machine.
geposted Sat 28 Apr 12 @ 7:36 pm
Why didn't you install the ASIO drivers?
If you want to get the best performance, that's what you need to do.
That's the ASIO drivers for the Gigaport, from the ESI Audio website - not ASIO4ALL!
geposted Sun 29 Apr 12 @ 4:39 am
