Forum: Old versions
Topic: VDJ 7 with Hercules DJ Control MP3
Hello there.
I bought Hercules DJ Controler MP3 some years ago and I ve been using VDJ 3.7 since then (cd was included). Well, I bought VDJ7 but I cant make it work with the controler. I tried to search for plugins but I found nothing.
Anyone had the same problem before? Any solution?
geposted Sun 29 Apr 12 @ 9:09 am
Please register your serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
NOTE: You will need the full VirtualDJ Pro to use Hercules DJ Console or any other MIDI controller. VirtualDJ Broadcaster and Basic do not support MIDI controllers as clearly stated on their product information/purchase pages and the product comparison page - If you have purchased one of these versions, you will need to upgrade it to the full Pro: https://virtualdj.com/buy/ - Contact support for further advice: https://virtualdj.com/contact/
Finally, make sure that you have the latest firmware and drivers for the Hercules DJ Console installed: https://virtualdj.com/wiki/Common%20Device%20Drivers.html
