Heya guys, loving the program so far and haven't been having any qualms with the program, everything has run smoothly with Virtual DJ itself.
The only problem I have right now is when I try and load a certain couple files, mostly from 1 or 2 artists specifically. I use headphones while I'm mixing, and rarely have sound issues - however, a few songs will only play in the left headphone when I load them. Thinking it might be a problem with the headphones, I loaded them into iTunes and they played just fine, both sides playing correctly. So the headphones don't seem to be the issue. I unplug them and try playing from my Mac's speakers - same problem, they only come from the left side. So it's not necessarily the computer or hardware's fault, I think.
Right now my suspicion is that the file itself is having trouble playing in the program. I went to the youtube link where I got the track and made a crappy converted mp3 from one of those converter websites, and that file seemed to play ok (but it didn't have as good quality). Right now this is my temporary solution, but I'd much rather use the original, crispier quality if there's a way to fix this.
I'm putting this post in the Mac forum because - 1) I'm *guessing* the file doesn't want to work specifically because I'm a Mac, for whatever reason, and 2) I'm not sure where else this topic would go.
In short, a couple (5 or 6 at most) of files don't work in Virtual DJ because they play on one side of the headphones, and it's not because the headphones are broken. What should I do to solve this peculiar problem?
geposted Wed 02 May 12 @ 6:26 pm
