Heres another one - I like to use stickam for live broadcasting but am not entire sure how to set up the audio. Is there a way the audio from virtual dj can be routed to my live webcam? I don't even need to use the mic, just the audio streaming directly thru stickam.
geposted Thu 03 May 12 @ 3:52 am
You have just to select your soundcard inside the stickam streaming config!
Stickam is the streaming software in that case, not VDJ ;-)
When you use both on the same computer.
When you use a second computer for the streaming, you have to connect the VDJ computer soundcard output with the second computer soundcard LINEIN!
Then select that soundcard inside the second computer inside the stickam config.
geposted Thu 03 May 12 @ 8:44 am
