Forum: Old versions
Topic: Can't out of a certain mode
Hi, I'm running VDJ 7.04 (b364) - the automatic updates says I'm up to date.
On the right side of the screen next to the search bar, about mid way up, there is a running total of how many files are displayed, and eyeball with an arrow and a double computer monitor icon. When I click the double computer monitor icon, the search window opens up full screen. The problem is, I can't seem to find a way to close it aside from rebooting vdj.
Anyone care to share the secret to closing the window that opens when I click that icon?
Much thanks!
Drew
geposted Thu 03 May 12 @ 2:14 pm
First: You're not running the latest update. We're at 7.0.5 b, build 380. You can get the latest version from your Download Center: https://virtualdj.com/download/updates.html
I had to try to understand what you mean, but I got it: If I do the same, the Double Monitor-icon is still visible on top. If I click it again, VDJ returns to its normal state.
Are you running VDJ maximized? The reason I ask is because this icon may be out of your screen on top. See if you can drag the screen down to make it visible again or try to switch to normal skin-size.
