I have a Reloop DJ-IE2 that I am trying to make work with my VDJ program as a midi controller. It will not work as a midi but the ASIO works. It does not show up in the mapper programming. I am using a windows 7 PC 64bit. I have read all types of forums on this and tried the different advice. To no avail I can not get it to work. I seen in a forum here a link to something that I think might work. But when i click on it it says Im not allowed to download an addon.
geposted Sun 06 May 12 @ 9:51 pm
you might need 64bit drivers for the midi to get recognised, I have the same controller, it's natively supported in vdj pro so should be plug and play... you may also need to change the firmware as there is a lot of different versions but only one of them works with vdj from memory.
geposted Sun 06 May 12 @ 10:02 pm
Make sure that you have the latest version of VirtualDJ v7.0.5b installed: https://virtualdj.com/download/updates.html
geposted Mon 07 May 12 @ 5:18 pm
