Hi,i'm having some problem with my Maya EX usb sound card in windows Vista and 7 and setting it up in my dj softwearas well keep getting this error (Asio not enough channels) this is a 5.1 so there more then enough channles in there.any help i'll be happy
geposted Tue 08 May 12 @ 2:27 am
Well from what I've just been reading on the product page, the MAYA EX is not an ASIO compliant soundcard.
So, you shouldn't be using ASIO - for a start it doesn't have ASIO drivers.
If you're using ASIO4ALL please be aware that it's NOT an ASIO driver, but is only intended to fool ASIO-only software into thinking your card is ASIO when it's not.
geposted Tue 08 May 12 @ 8:15 am
yes MAYA EX is ASIO compliant soundcard i download the asio driver on the company site,i'm only getting 1&2 channel but not 3&4 to monitor my songs i had it working befor don't know if it's win vista or 7 problem i'll try win xp and see.got a small gig comeingup do not want to carry too many things.
geposted Tue 08 May 12 @ 7:51 pm
ok got it to work thanks for the info
geposted Tue 08 May 12 @ 8:14 pm
Well I based my reply on what the ESI web site stated - and it shows the EX as not being ASIO.
http://www.esi-audio.com/products/mayaex/
geposted Wed 09 May 12 @ 5:39 am
