So I just bought a used but in great shape Denon 4500 and to be honest I am not that techy of a guy, so before I start I thought maybe I would ask if anyone who has this unit for any tips before I start.
I have a dell laptop and the Denon 5000 mixer. and of course VDJ 7
Also, and I know this is not a Denon room but since they both have sound cards built in,,, is one better than the other?
geposted Tue 08 May 12 @ 1:18 pm
I guess they both use the same Denon Asio drivers so they should sound about the same.
HC-4500 is a great piece of kit and is extremely configurable with VDJ script.
Please see here and let us know if you need any more info.
https://virtualdj.com/contact/answers.html?id=107
Keith
Keith
geposted Tue 08 May 12 @ 2:19 pm
I think I did it all right, the controller reads VDJ when I put in a song.... but VDJ does not show the 4500 as a driver.... arrggg... any thoughts?
geposted Tue 08 May 12 @ 8:34 pm
Chuck isn't the mixer a Pioneer DJM-5000? As mentioned check the ASIO drivers and the firmware on the HC4500.
geposted Tue 08 May 12 @ 9:18 pm
Please see:
https://virtualdj.com/wiki/DN-HC4500.html
geposted Wed 09 May 12 @ 5:30 am
You a have to to use the denon ASIO driver Installed on your computer and select ASIO soundcard in the Virtual DJ Software, You can get the driver from the denon website..
Cheers
DJMikeD
Cheers
DJMikeD
geposted Wed 09 May 12 @ 2:14 pm
be sure to check out www.denondjforums.com for additional support.
and as mentioned you def need the ASIO drivers installed on your lappy
geposted Thu 10 May 12 @ 12:26 am
thanks all
geposted Wed 30 May 12 @ 12:04 pm
