Hello VDJ forum. I'm new here, and want to say thanks in advance if you can help me.
I'm using the Mixtrack Pro with Numark cue which is updated on line to the newest version.
When I create a loop manually the software overrides my loop out point and automatically makes it in line with what Cue thinks is the correct measure. It is throwing my mixes off because it is not correct.
Is there an option to make the software stop doing that.
I know that the controller has 2 different loop modes. If the light is blinking it is supposed to be automatically measured.
I thought that if the light on the button is not blinking it is in manual loop, but it defaults to whatever the software thinks is the correct loop out every time anyway.
It's ruining some of my mixes. I usually have to just use a cue point and manually loop back to the hot cue instead of actually looping.
Can you turn off auto loop inside the software?
Please help.
Please help.
geposted Wed 09 May 12 @ 8:43 am
you have smart loop enabled, it is the padlock near the loop section of the default skin. alternatively you can map a different button on your controller with "smart_loop 1 ? on & smart_loop : smart_loop" (it will only change the looping mode, it doesn't actually loop)
or you can map your keyboard with "deck left smart_loop" (left can be 1, 2, 3, 4 ect... or right)
geposted Wed 09 May 12 @ 10:51 am
OK Thanks. I'll check that out.
geposted Wed 09 May 12 @ 10:54 am
