I just Upgrade to VDJ Pro 7 form and older version of VDJ. Before I start the program up my system CPU is at 12% and when I start the program it jumps to 80% then to 100% when a song is added and starts to play. The song then will fade in and out as it scrolls across the MP3 deck. The system is running windows XP with a Maya 44 Soundcard and has the required system per VDJ. The older version run great and the upgrade runs on my laptop. Any ideas??? Thanks DJThawk
geposted Wed 09 May 12 @ 11:56 am
Is it a legitimate version of Pro downloaded from this site?
If not, bad code may be the reason why.
Keith
Keith
geposted Wed 09 May 12 @ 12:12 pm
Yes... Purchase along time ago..... I have had VDJ5 for about 3 years and finally upgrade to VDJ 7 and now these promblems. I tried it on my laptop and it works fine. This is for my main rack system that thing are going wrong. :-)
geposted Wed 09 May 12 @ 1:10 pm
Yes.... This upgrade is a legitimate version of Pro downloaded from this VDJ site. Thanks DJThawk
geposted Wed 09 May 12 @ 1:11 pm
Are you running the new version with a skin of the correct size?
The skin resolution has to match the resolution of your monitor.
geposted Wed 09 May 12 @ 3:26 pm
Please register your Pro serial number on the following page https://virtualdj.com/users/edit.html and then download the latest version from https://virtualdj.com/download/updates.html
Then see the following FAQ page: https://virtualdj.com/wiki/Performance%20Issues.html
As above, the issue is most likely caused by resizing or maximising the skin. Once registered, you can download a custom skin that exactly matches your screen size from https://virtualdj.com/addons/skins.html
geposted Thu 10 May 12 @ 6:56 am
Thanks...... i will give it a shot and let yopu know how it works.
geposted Thu 10 May 12 @ 10:00 am
