Forum: Old versions
Topic: Denon 6000 Crossfader autostart
Okay this is driving me crazy and I can't figure out how or where to look in the script to disable this crossfader that always turn on the right side as soon as you move the crossfader to the right it automatically start playing the track on the right. I set the audio and video on so I know it something to do with that because when I only use audio the software cross fader does do anything but when I use video only the crossfader work and it also start the track when you move to the right side.
I'm using the script that I could use the right setting instead of the default 1-2-3-4. I want total control on the cross fader so I can beat match when I move the cross fader. This is getting me to the point of switching over to traktor pro 2 and I don't want to since I own VDJ and I'm enjoying the software.
Can someone point me to the right direction?
geposted Wed 09 May 12 @ 10:28 pm
So if that's the case where could be in the skin mapper DN-MC6000 CH 3<1 L-R 2>4 Mapper v 1.2 by Zacek100? What am I looking for so I can disable it. Even when using "shift-play" to turn autoplay on/off doesn't seem to work?
I don't mind going in to make change, I would rather learn it myself to better understand VDJscript.
You would need to ask the author of that custom plugin/skin (zacek100)
The default native mapper for the MC6000 included with VirtualDJ does not have this function.
The mapping line posted above should disable fader start for all decks if you map it to a key of your choice.
Or if you want to be able to toggle fader start on/off for each deck, try mapping a button to fader_start.
For further info about how to map a button, please see: https://virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
