This is sort of a continuation of another topic I posted.
I have a Mixtrack Pro and it's headphone volume is too weak to use when the music is really loud. I can barely hear the cue even when it's turned all the way up if I'm playing at high volume.
I wonder if you can configure the sound to cue out of the computer's headphone jack.
I was told to choose 2 sound cards, by someone. My problem is this. I like to run my output in mono. I have it configured like that right now.
Can someone tell me the exact configuration to have my L&R output feeding in mono plus use the headphone output on my computer for cuing?
The headphone output on the Mixtrack Pro is just way too weak.
Thanks for any input.
geposted Mon 14 May 12 @ 9:59 am
You'll have to use the advanced config section, from there you can set it up how you want. It's pretty straightforward so you shouldn't have any trouble setting it up.-
Hope that helps
Huey
Hope that helps
Huey
geposted Mon 14 May 12 @ 10:14 am
OK got the headphones to work off the computer headphone out and it is A LOT LOUDER.
Thanks for all of the help.
geposted Mon 14 May 12 @ 8:11 pm
