Just got the mixer in today. Does anyone know how to hook it up with a pair of V7's? I've already installed the 900 mapper.
geposted Mon 14 May 12 @ 10:01 am
v7 s usb cable with cat5e and you should be fine as long as you have the drivers loaded on your computer.
C stoll made a grt guide for you
https://virtualdj.com/forums/130863/Hardware_Technical_Support/Numark_V7_-_Setup_-_1_and_2_unit_settings.html?page=1
you also can use the pioneer sound card for your decks instead of the numark.
geposted Tue 29 May 12 @ 4:12 am
Wow, I just link the V7's together as you would through a standard mixer. Then chosethe V7 soundcard. Thanks for the info!
geposted Tue 29 May 12 @ 4:32 am
Everytime I selected the pioneer soundcard it would say not enough something.
geposted Tue 29 May 12 @ 4:36 am
channels... it wouls say not enough channels, you need to make sure the pioneer drivers are loaded asio drivers im sure for windows. and then assign each channel to one of the lines you then should be able to do four decks ... 4 different audio outputs and map the controillers to swap from deck 1 and 3 to 2 and 4 see posts .....
geposted Fri 01 Jun 12 @ 1:01 am
OK, I'll tryThanks!
geposted Fri 01 Jun 12 @ 4:27 am
