I just purchased VDJ Pro Full v7.0.5b. The install went great, but when the splash screen came up, the "Registered To" info is wrong. It's registered to my "OLD" email address. Is there any way I can change this?
Thanks...
Doc Allan
Rockin' Horse Roadshow Entertainment
Thanks...
Doc Allan
geposted Tue 15 May 12 @ 5:46 pm
You can change your emailaddres under "Modify my Profile" just above your post. If it remains in the splashscreen you should create a ticket under "Support / Help".
geposted Tue 15 May 12 @ 6:20 pm
Thanks... I'll do that!
geposted Tue 15 May 12 @ 6:36 pm
Please note that you will need to uninstall and then download and install VirtualDJ again for the change to take effect.
geposted Wed 16 May 12 @ 6:40 am
