Hi Guys,
IM using VDJ PRO 6 with the MAYA soundcard and serarto timecode vinyl on technics 1210's. Everything works great apart from there is too much bass being outputted, has anyone come across this problem and can help. Thanks guys
geposted Fri 18 May 12 @ 8:09 am
VirtualDJ v6 is a very old and out of date version of the software. There have been many changes and improvements to the software since then (See https://virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.5b
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/
Once you have done this, check the position of the bass knob on your mixer. Also, check that your speakers are connected correctly. If the problem persists. turn down the bass knob on your mixer.
geposted Fri 18 May 12 @ 4:14 pm
