Forum: Music discussion
Topic: Where's my Master, Master+Mic and Line-In options?
Hi all,
I've purchased the Virtual DJ 7 version and I'm trying to sync it to stream with my radio site, separate broadcast IP than the default Virtual DJ IP that's given from application. I'm putting in my correct broadcast IP address from my radio site, correct server, server is on....but when I go to broadcast it gives a "BROADCAST ERROR.....SERVER CONNECTED". It's like its talkign to the server fine..but still gives an error.
Looking at instructions on youtube, I'm missing 3 options: Master, Master+Mic and Line-In. When I go into config, I only have autostart and the Formats OGG and mpeg. I really think this is what's keeping me from hearing my broadcast on my site....
PLEASE HELP...how do I get those options???
geposted Sat 19 May 12 @ 11:48 am
Please have a look here:
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
If you have further problems, please contact the support.
https://virtualdj.com/contact/
BTW:When you register youir purchase under your account, you will find in your personal download center at anytime your "actual" version.
If we provide a update, you also will find it there.
https://virtualdj.com/download/updates.html
Also you will be able to download our goodies, skins, efefcts etc.
https://virtualdj.com/addons/skins.html
I'm having the same issue, did you find a solution?
It's easy :-)
Check the informations above your post!
