Forum: Old versions
Topic: Help setting up Denon MC6000 with 2 Denon S1200's
Hello,
Has anyone tried to run the Denon MC6000 with 2 Denon S1200's? I cannot seem to the the configuration to run correctly.
I am running VDJ7
Want to run Deck 1 - S1200, Deck 2 MC6000, Deck 3 MC6000 , Deck 4- S1200
Thanks,
Dj Rob
geposted Sun 20 May 12 @ 7:13 pm
If you mean deck 2 on left of MC6000 and deck 3 on right of MC6000, then this is not possible. On the MC6000, decks 1&3 are on the left and 2&4 on right.
The S1200 is a single deck controller and can be assigned to any deck by pressing the EJECT button (The current assigned deck number is shown in the track digit to the left of the LCD display.)
If you are using the MC6000 in software MIDI mixer mode (PC MIX), then you can optionally change the order of the software mixer section of the MC6000 to 3->1->2->4 if you wish by following the instructions on the following page: https://virtualdj.com/wiki/DN-MC6000.html - You could then assign the S1200's to decks 3&4, which would be the outer pair of faders.
