Hey there folks, I am hoping you guys are going to be of more help than the Reloop forum people. I have been dealing with them for 3 weeks, and have gotten nothing but aggravation.
I have this brand new Reloop Mixage CE LTD, I plugged it in, opened VDJ, and quickly realized I needed drivers.
I have installed three versions of ASIO. These do nothing, and the controller does not pop up inside the ASIO settings window.
Reloop_ASIODriver_WIN_1.00
Reloop_ASIODriver_WIN_1.10
Reloop_ASIODriver_WIN_1.15
but I am not even convinced I need ASIO...
In Settings -> Sound Setup
what should be listed as my input and sound card?
i would like to use main and headphones for output, I am using a cheap 2.1 external sound card to get output on multiple channels, this setup has worked in the past - but im not sure how this changes now that im trying to use a controller.
do i need to use an advanced configuration? if so - why isn't the controller appearing as a selectable piece of hardware?
geposted Wed 23 May 12 @ 9:45 pm
Hi,
your Mixage CE LTD doesn't have onboard sound. Anything you wrote about audio, ASIO a.s.o. you can skip/forget.....
The controller is just that: a controller. You could have left your audio-settings the way they were with your 2.1 USB-card (although you can only pre-listen with a splitter-cable) and add the controller to your setup. You could check the Reloop-site if any drivers are needed, but I think the Reloop can work eith the standard Windows HID-drivers.
But: The Reloop will only work with the Home Free Edition for 10 minutes per session. If VDJ LE is supplied with the Reloop Mixage just install that. Otherwise you need to buy the Full Pro-version http://www.virtualdj.com/buy/index.html
geposted Thu 24 May 12 @ 5:52 am
we were using an older version of vdj, downloaded the new one and it works.
geposted Thu 24 May 12 @ 12:34 pm
You cannot add his serial number to your profile. His serial number is for his own personal use only and MUST NOT be disclosed to or shared with anybody else. Please see: http://www.virtualdj.com/wiki/Can%20I%20share%20my%20Serial%20Number.html
Using his VirtualDJ that is already installed on a computer that belongs to him is OK providing that he is not also using it at the same time on another computer. Please see: http://www.virtualdj.com/wiki/Can%20I%20install%20the%20software%20on%20a%20new%20computer%20or%20more%20than%20one%20computer.html
If you like VirtualDJ, please support the software and its future development by purchasing your own license, which you can use on your own computer: http://www.virtualdj.com/buy/index.html
geposted Thu 24 May 12 @ 12:58 pm
