Hi all...just some ??????... About vdj 7 and the upcoming vdj 8
In 7 ...Can the 4x4 video clip bank plug-in be midi mapped ???....I would like to use my Roland mv 8000 midi sequencer / sampler to control the sampler &/ or the video clip bank plug in , in the software
Can I run my numark ns7 midi controller ( 14 bit HID midi ) and two other SD midi controllers ( mv 8000 & pcr 500 midi keyboard ) at the same time ?..
In the video demo off vj 8 what was the iMac Thay used....going to buy one just need to know which one was working with vj 8
In the vdj 8 sampler ....how many sampler pad & how many sampler bank can we use
geposted Wed 23 May 12 @ 11:21 pm
you can map the clipbanks with "video_fx_select "clipbank" & video_fx_button #" just replace the # with the appropriate bank number.
you can use multiple controllers at the same time, but do a google search to see peoples reactions of the ns7 "site:virtualdj.com ns7"
Atomix generally use bootcamped macs running windows for expo's, time will tell what mac effect support is like in version 8 although I assume it will be the same as pc, but the community generally only submits pc plugins and they are better than the ones from atomix.
geposted Wed 23 May 12 @ 11:31 pm
