Testing out the LE upgrade atm and I'm having trouble working with the mapping I downloaded from the Numark website.
Basically I'm getting a situation where the leftdeck and rightdeck are assigned to, say, 1 and 2, respectively, but the jog wheels on both sides of the N4 are acting on the same deck (the selected deck).
What's the right behaviour for the aligned controls (play, cue, jogwheels, pitchbend etc.)? Should they follow the <side>deck (presumably the case) or the default deck?
geposted Thu 24 May 12 @ 1:13 pm
you might have to post the mapping for one of the controls as that is very weird behaviour, everything should follow the left and right deck, that means the deck in focus on either side of the controller
geposted Thu 24 May 12 @ 2:11 pm
Hi,
Thanks for the reply. :)
Adding a refresh_controller to the end of the action for the switch decks key seems to have fixed it.
Semi-related question: if I understand what I've read right, select sets the default deck for actions that don't have a side and if that's the case then hypothetically my selected deck shouldn't really matter, right?
Cheers!
Cheers!
geposted Thu 24 May 12 @ 6:16 pm
yes if you map "deck default effect active" the action will be performed on the currently selected deck, that the one your listening to in your headphones.
geposted Thu 24 May 12 @ 9:02 pm
