Virtual DJ LE: I've used the Automix playlist plenty of times but all of a sudden the ability to make a playlist is gone. The slide bar on the right is not even there. Any ideas on how to get it back?
geposted Fri 25 May 12 @ 6:25 pm
VirtualDJ LE is limited software and doesn't support playlists or automix. These and other Pro features are only available during the 20 day trial. Pllease see http://www.virtualdj.com/products/comparison.html
This will explain why it suddenly disappeared because your trial has ended.
To use playlists, autpmix and much, much more, you will need to upgrade to the full VirtualDJ Professional at a discount: http://www.virtualdj.com/buy/index.html
geposted Sat 26 May 12 @ 12:59 pm
