I know it has probably been listed with "how to" but I have spent the better part of a week trying to figure some stuff out.
I just did an upgrade to Snow Leopard 10.6.8.
I have a 2.2. ghz intel core 2 duo
1 GB 667 MHz ddr2 sdram
DN HC4500 and a DN X500 mixer
I used to be able to use the Denon to play pause and control virtual DJ. also the name of the song USED to show up on the controller.
Nothing is working OTHER THAN the sound card part of it.
HELP!! I mean it is usable but soooooooo tough when you are used to something. I did download the MIDI file from this site and copied it into the mapper folder and HOPED that it would work. But NOPE!!
thanks in advance
Josh
thanks in advance
Josh
geposted Sat 26 May 12 @ 12:56 pm
Do you have the latest firmware installed from http://www.denondj.com
Also, the latest VirtualDJ v7.0.5b: http://www.virtualdj.com/download/updates.html
See: http://www.virtualdj.com/wiki/DN-HC4500.html
geposted Sat 26 May 12 @ 1:09 pm
