Can anyone tell me where I can preview samples & effects before I buy them? Thanks in advance!
geposted Sat 26 May 12 @ 2:08 pm
You don't purchase samples or effects from our site - they are all free to licensed users.
geposted Sat 26 May 12 @ 3:47 pm
I know that but I can't preview all of them + there's a lot of samples and effects that I hear other DJs using that are not available in VDJ,If I could get everything I need from VDJ I would.
geposted Sat 26 May 12 @ 4:08 pm
Samples are just audio files, it's easy enough to make your own or use any that are available.
As for effects, we have a massive selection available and coupled with VST support I'd say probably more than pretty much any other DJ app.
geposted Sat 26 May 12 @ 4:09 pm
I guess I'll have to keep downloading them until I find what I need :-/
geposted Sat 26 May 12 @ 4:13 pm
You can search them to narrow down what you're looking for...
geposted Sat 26 May 12 @ 4:19 pm
what do you need? there are only a couple of different types of effects, the rest is sound quality and combinations to make new sounding effects.
geposted Sat 26 May 12 @ 4:21 pm
I'm looking for an effect or sample that makes kind of like a hydraulic pump sound when it releases pressure,I'm not sure if you can relate but as always my way of explaining things is not the best :-/
geposted Sat 26 May 12 @ 5:30 pm
You mean white noise?
There are plenty of sound effect sites which allow you to listen to the sounds....
geposted Sat 26 May 12 @ 5:49 pm
groovingdj,I don't now what the name is,I downloaded white noise from VDJ and whenever I try to use it it doesn't make any sound. Can you tell me the name of some of those websites?
geposted Sat 26 May 12 @ 5:54 pm
I like tex_zk's "noisebell" for adding whitenoise... it has a nice little bit of resonance and an echo trail that can be set at 1/2 or 1 beat... slider 2 is the one that makes the sound, slider 1 is volume.
Deun deun's, whitenoise v.3 sounds great especially with the sidechain, but lacks an echo.
geposted Sat 26 May 12 @ 8:15 pm
Thanks a lot synthet1c I'll try that.
geposted Sat 26 May 12 @ 9:23 pm
