is there a skin that allows you to use a playlist to use the auto mix function like you can do with pro7? for djc 5.2.2
geposted Sat 26 May 12 @ 6:42 pm
No, it's a function of the browser and LE doesn't support playlists.
LE versions don't support custom skins either.
geposted Sun 27 May 12 @ 7:34 am
