What is the best in your view? (please give reason).
geposted Sun 27 May 12 @ 5:12 pm
what exactly is it that you are asking for?
If you are asking if CDJ's are better than Virtual DJ, well......
The use of USB Cdj's, with built in sound cards, is simply amazing when it comes to controlling the many different features of virtual DJ. In addition, CDJ's give you the option of not only MIDI mode, but you can also use them with cd's, USB thumb-drives, and SD cards. MOst of them even allow you to link them, so as to use only one thumb-drive readable by both units.
Virtual DJ is highly enhanced by the use of cdj's, however, this is not only true for CDJ"S but also for a grand variety of MIDI controllers designed to be used with virtual dj.
There are many options to choose from when it comes to cdj's, and or MIDI's, it's all up to your budget, and what ever makes you feel comfortable when it comes to mixing.
I hope this gives you an answer to your topic.
geposted Sun 27 May 12 @ 9:56 pm
I have found that the one that does what I need it to do, works the best for me. We can't make that decision for you.
geposted Sun 27 May 12 @ 11:28 pm
