I have a Behringer DDM4000 mixer.
Please show me the syntax on how to map a few buttons;
1- I am having trouble getting the ‘Toggle’ verb to work.
I would like to have the channel crossfader assign button toggle between channel 1 left, and channel 1 thru. (I assume 'thru' will disregard the crossfader position, which is the action that I want).
2- If I am playing a track and I change the loop size, I would like to map a button to push to reset my loop size back to the original loop setting, or reset to a certain length or beats.
3- I would like to listen to either the effects, sample, or loop when I press one of the PFL switches. What is the map to listen to multiple outputs from one PFL switch. It would be also OK to hear them all at one time through the PFL instead of individually.
4- Is there a way to map a ‘reverse’ or ‘dump’ loop (reverse looping or dumping).
Thanks in advance for the help!
Clay
Clay
geposted Tue 29 May 12 @ 1:49 pm
Help please?
Even if you can only answer one of the questions....
geposted Wed 30 May 12 @ 7:58 am
