Does anyone run VDJ with the denon dns 5000 cd players? Do they perform well with VDJ, and do like them? Or are the 3700 better?
geposted Wed 30 May 12 @ 10:25 am
the 5000 are just cd players that you need timecodes to make it work with VDJ. they should work well as if you were playing CDs maybe with some latency depending on the sound card that you use. as the 3700 are controllers as well as sound cards they can connect to your PC and work like if they were a mouse or keyboard that you can program as you want (change the play to become CUE or behave differently)
geposted Wed 30 May 12 @ 1:32 pm
what kind of controller do you guys use for the dns5000 i have the hercules rmx and having a hard time getting them to work.
geposted Wed 10 Oct 12 @ 12:30 am
