Hi everybody,
I bought an hercules 4-Mx with Virtual DJ LE. After installing the softwares and connected the console, which turns on, I can't control Virtual DJ with the Hercules. Why? Do I missed something? Please help me! I've a MacBook Pro.
Thanks
Thanks
geposted Wed 30 May 12 @ 2:52 pm
Depending on which version of OS X you are using, it may be necessary to install the latest drivers available on the Hercules support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=263&cid=1
You'll also find, in the Download Center of your VDJ profile the latest update for VDJ LE.
Finally, verify in the DJ Control panel that the MIDI Channel is set to 1-2
geposted Thu 31 May 12 @ 6:29 am
I downloaded the driver and installed it correctly... I had installed the new version of VDJ yet... But why the problem isn't solved? Is there some Mac configuration that I didn't do? What do you have to do normally to get started your console? just open VDJ and connecting it to the computer? :S
geposted Thu 31 May 12 @ 11:11 am
Maybe it's just the way you typed it, but you know that you first have to connect the controller before starting VDJ? Make sure it is recognized before you start VDJ.
geposted Thu 31 May 12 @ 6:05 pm
Yes I connected it before opening the vdj... Actually the computer recognise the console but I don't know if vdj does... How can I do? Which input output do I have to select in the preferences?
geposted Fri 01 Jun 12 @ 12:38 am
If the console works with the the following procedure, it should work in VDJ:
http://ts.hercules.com/faqs/eng/her_eng_00414.pdf
As for the audio configuration:
- Input : NONE (unless you want to use a microphone [MIC] or an external source [Line-Ins])
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ Console 4-Mx
geposted Fri 01 Jun 12 @ 7:23 am
