Hey guys,
Im using a timecoded system, and i was wondering is there a way to set up VDJ to show the BPM changing when you move the pitch control on the turntable. I know the BPM shows the current bpm of the song when you use the pitch control on the software, but i want to be able to use the turn table pitch control, and VDJ BPM counter change with it.
Is this possible? If so how. I hate using the sync button, to me that isnt really Djing.
Thanks,
Thanks,
geposted Fri 01 Jun 12 @ 8:48 am
you should already be able to use the turntable pitch fader and the pitch slider and bpm will change in the software. maybe you have one of the smart modes or beatlock active, they are locks on the default skin...
You should register your serial so you can download the amazing effects only available once you have registered ;-)
geposted Fri 01 Jun 12 @ 9:13 am
ill have to check my locks, i know i have keylock on atm, that wouldnt affect the BPM changing though. How do you check the other locks on the default skin?
geposted Fri 01 Jun 12 @ 9:52 am
You look at them and see if their on or off, lol!!
geposted Fri 01 Jun 12 @ 10:03 am
