I'm trying to map specific effects on my keyboard and have it so the effects operate independently with each deck. From what I've seen, the syntax in the keyboard mapper is supposed to go something like this....
lets say i want the "Q" key to be the flanger for deck 1 (Left), so I'm supposed to type in (deck 1 effect "flanger" active) with out the parenthesis and then if I wanted "P" to be the flanger for deck 2 (Right) I would type the same except with deck 2 in front.
Problem is....I do that and when I engage the effect it lights up both decks, which isn't what I wanted. Am I missing something?
geposted Fri 01 Jun 12 @ 3:45 pm
bump trying to get an answer
geposted Fri 22 Jun 12 @ 1:34 pm
You used the correct syntax, that should have worked...
maybe try "deck left effect 'flanger' active"
geposted Fri 22 Jun 12 @ 1:59 pm
