could you help im new to all this but im after a wiring diagram or any help .......... im wiring from my laptop to a karaoke system then through an amp but when i plug the 3.5jack in to pc then red n white into karaoke system i get no mic sound until unto i unplug the white lead............then im getting mic outta 1 speaker n music from the other!!
am i doing somthing wrong??
please help
Thanks in advance
please help
Thanks in advance
geposted Thu 07 Jun 12 @ 5:53 am
Yes.
What "karaoke system"? Be precise. Make, model etc.
itsbrose wrote :
i get no mic sound
Well where is your mic plugged in?
geposted Thu 07 Jun 12 @ 6:35 am
Also which programme/software are you using to run your karaoke.
Are you just using the screen on your laptop to read the words or is it linked up to a monitor/screen.
I'm assuming if you have a karaoke system that is where you need to plug in your mic, from there you make a connection from the output to your amplifier which then goes to your speakers.
If you have active speakers the link will go directly from your karaoke player to the input on your speakers.
geposted Thu 07 Jun 12 @ 7:33 am
hi thanks for your help im using Virtual DJ pro n the karaoke system is a friends n just says Ultmate on it it has 2 mic ports on the front for the mics
ive a 3.5 phono going into red n white (pc to karaoke system)
red n white to red n white (karaoke system to amp)
ive pics if it helps? i am thankful or ur help n sorry if i sound useless (thats coz i am abit) :P
it dose all work but its the fact that cant have music n mic coming outta all speakers at the same time, im gettin mic from 1 speaker n music from other soooooooooooo annoyin
geposted Sat 09 Jun 12 @ 1:04 pm
You are using vdj pro but I see that you're not a licensed user so I'm only left to assume that its a hacked one.
geposted Tue 12 Jun 12 @ 4:59 pm
ur more than welcome to assume what u like!!! what r u on about?
geposted Wed 13 Jun 12 @ 7:15 am
