I'm looking for a plugin that will display the NAME or Cover of the song when it LOADS.
What i'm trying to accomplish:
I do Sweet 16 alot and I have the 16 songs ready to be play when the Candle speech is over for each sponsor. I like to take pictures when this is done and usually I go back and forth to my booth to load next song.
Once the song is loaded ( even in 4 decks), I remotly START PLAY when it's time.
I have change this so I don't have to go back/forth to my booth by just put songs in order/playlist and remotely LOAD/STOP/PLAY each songs. The problem that I might encounter is not knowing if the song correctly LOADED into the deck player.
I see the TITTLER plugin, but it only shows on the screen when you have already START the song. i wanna see the SONG/COVER when Iloaded it making sure I did load the next right song.
TIA
TIA
geposted Thu 07 Jun 12 @ 4:05 pm
I see the SHOW Cover by DJcel and that might do the trick. I just need to SCAN covers within VDJ (the COVER that's already TAG won't show).
I'll go ahead and use this for now. I have a Sweet 16 Friday night.
If there is anythig else that I might have missed, please LMK.
TIA
TIA
geposted Thu 07 Jun 12 @ 4:21 pm
This worked out really well last Friday. The only thing that you have to make sure to do is, have a ANY SONG loaded on on the other DECK or else, when it's time to load the next song, it will load it to into the EMPTY Deck. I just wanted it to load on one deck all the time.
Thanks for the plugin.
geposted Sat 09 Jun 12 @ 8:50 pm
