Hi
I have a problem where sometimes when i drop a video onto a deck, the audio loads but no video.
It happens mostly if i have previously loaded the video onto a deck then not played it (i.e. i have loaded a track then changed my mind & ejected it), when i load a few tracks later, the video stays on the previous track (normally black where i rewound to beginning), and when i press play, the transition effect doesn't happen, the video output windows goes blank.
I use mainly mp4 files but this happened the other day with a .vob file.
It has also happened occasionally with a file the first i have loaded it that session but this happens very infrequently.
Any help would be appreciated as when i forget to check the video has loaded or if i'm rushing (normally when i do end up changing the next track in the deck) it means either blank screen for the whole track or i have to load it again in the other deck & mix in to it to get video to play.
Krys
Krys
geposted Fri 08 Jun 12 @ 2:16 pm
In config>video>decode in multithread, is it checked? Uncheck and see what happens.
geposted Mon 18 Jun 12 @ 11:54 pm
