ok so i have looked at all info and not getting it . so can someone tell me how to set up time code video control.
i have a MAC, 2 1200's, a DJM-T1 mixer , and an audio 6 traktor box.
currently when i go to time code set up i get no signal. please if you can take me step by step on what inputs and out puts i should be using ect
geposted Sat 09 Jun 12 @ 11:44 am
no answer so i guess i will just go out and get serato video this weekend.... thanks anyways
geposted Mon 11 Jun 12 @ 3:57 pm
Most information is available on the wiki part of this website.
https://virtualdj.com/wiki/Timecode%20Config.html
keith
keith
geposted Mon 11 Jun 12 @ 4:00 pm
thats the problem i read all that and still not up and running... i thought maybe someone could give me a hand but seems it just may not be in the cards for me to use vdj anymore
geposted Mon 11 Jun 12 @ 5:04 pm
have u been successful with setting up time code audio?
geposted Thu 21 Jun 12 @ 2:04 am
no
geposted Mon 02 Jul 12 @ 9:42 am
What soundcard are you using, the DJM-T1 or the Audio 6??
Also read this, https://virtualdj.com/forums/146709/General_Discussion/Perfect_Timecodes__.html
Those are my findings.
Let me know if you need more help
Huey
Huey
geposted Mon 02 Jul 12 @ 10:16 am
All u should have to do is plug the rca leads of turntables into the phono input of the mixer. Then on the mixer make sure u have your input selection on USB. U also need your mixer plugged in to ur laptop via USB...
Let me know if u get that far.
Other things to consider would be to make sure the pioneer software utility application is installed on ur mac. I have a djm 900 and I am needed to install that software. There are settings in there too for each channel. Make sure each channel on the mixer is set to USB within the pioneer software.
Any more details about ur situation would be helpful also...
geposted Mon 02 Jul 12 @ 7:09 pm
i have been djing for awhile so the basic setup is fine...... going to check the pioneer setup and report back
geposted Thu 05 Jul 12 @ 11:58 am
Huey
Huey
using the audio 6.....didnt thing the djm-t1 would work alone
geposted Thu 05 Jul 12 @ 11:59 am
wait are you saying i dont need the audio 6 in the chain????
geposted Thu 05 Jul 12 @ 12:04 pm
I don't have that mixer yet, it'll be here next week, but try setting it up just using the mixers soundcard. It should work from what I've been told. Really wish mine was here!!
geposted Thu 05 Jul 12 @ 3:06 pm
ok i got some gigs the next two days will give it a go... thanks
geposted Thu 05 Jul 12 @ 8:14 pm
Yeah... no need for the audio 6. I'm not 100% positive because I don't have the exact same mixer as u but I do have the djm 900 which is similar. I used to use an audio 8 but don't need it any more
geposted Sun 08 Jul 12 @ 11:00 pm
You get sorted yet bro??
geposted Tue 10 Jul 12 @ 10:38 am
nope not at all
geposted Tue 17 Jul 12 @ 11:58 pm
