What is a great cheap table-top controller that has a vinyl/scratch mode and is compatible to Virtual Dj?
geposted Sun 10 Jun 12 @ 7:03 pm
Hercules e2 will be the cheapest you can find, but it has no built-in soundcard and won't let you browse through your effects list (which is a necessity for me and any DJ).
I'd say the Numark Mixtrack or Numark Mixtrack Pro. The Pro has a built-in soundcard and allows you to pre-listen. The jogwheels are awesome and it's a pretty solid controller. Then you also have the Hercules DJ Control Air, the Hercules MK2 and the Hercules RMX.
Read up on those I mentioned, and you should be good to go. Those are pretty much the cheapest you'll find.
geposted Sun 10 Jun 12 @ 7:20 pm
Have the mk4 (hercules) and the mtp go with the mtp if you larger hands or start with the mk4 and it has a built in soundcard
geposted Sun 10 Jun 12 @ 11:52 pm
Hercules MP3e2, MK4 and RMX don't have touch-sensitive jogwheels, so are not ideal for scratching.
Numark MixTrack and MixTrack Pro have touch-sensitive jogwheels and aren't too expensive, so would probably be your best option.
Also, the new Hercules DJ 4Set and 4-Mx have touch-sensitive jogwheels.
geposted Mon 11 Jun 12 @ 7:17 am
