I'm trying to map a few things but having issues.
trying to map
Command+ Left = load deck 1
Command + Right = load deck 2
Command + Down = Get info on selected track..
any help would be great
Thanks.
trying to map
Thanks.
geposted Mon 11 Jun 12 @ 12:57 pm
I don't think you can use the CMD key on a mac for mapping, it's protected by MacOS.
Keith
Keith
geposted Mon 11 Jun 12 @ 1:23 pm
Keith, the Command keys work like that is SSL. So just trying to immolate for ease of switching between the 2 softwares.
But not the CMD+down.
geposted Mon 11 Jun 12 @ 1:53 pm
OK I got to work somewhat.
CMD+Down = browsed_file_info = open file info screen on selected track.
I also got
CMD+Left = load = load the selected song on the deck.
As it is right now I can load a track to the none active deck using this shortcut, but I want to specify which deck to load. Can't seem to figure it out, like I talk about in my first post.
I also got
geposted Tue 12 Jun 12 @ 11:14 am
Try "deck left load" and "deck right load"
Keith
Keith
geposted Tue 12 Jun 12 @ 12:34 pm
Thank you Keith that works perfect, I was trying that but putting the underscore in.. works like a champ with out the underscore.
geposted Tue 12 Jun 12 @ 1:51 pm
No problem, glad you got it working.
I guess the cmd key is now accessible to mapping as it certainly didn't work when I had the Macbook Pro.
Keith
Keith
geposted Tue 12 Jun 12 @ 2:07 pm
