Sorry, but I cant speak English well because Im studying it.
I want to know if the new HERCULES DJ CONTROL INSTINCT is compatible with virtual DJ 7 because I have seen the software which you can mix that DJ CONTROL and I hate it
geposted Sat 16 Jun 12 @ 5:49 pm
Because Im going to buy it
Yes it is compatible - because it's a MIDI controller.
Any MIDI controller that sends out standard MIDI control signals can be used with any software which understands MIDI signals.
geposted Sun 17 Jun 12 @ 7:07 am
It's not currently natively supported by VirtualDJ - Please see: https://virtualdj.com/wiki/Is%20MIDI%20controller%20NAME%20supported%20by%20VirtualDJ.html
If you wish to use it with VirtualDJ, you would need to map it yourself (See https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html )
Purchasing a controller that is already natively supported is strongly recommended: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
In your case, purchasing a controller that comes with VirtualDJ LE included is also recommended because you don't currently have a license for the software. VirtualDJ LE can also be optionally upgraded to the full Pro at a discount (Price depends on the product purchased.)
geposted Mon 18 Jun 12 @ 4:40 am
The VirtualDJ mapper will be available inside my Hercules mapper pack https://virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
when HERCULES DJ CONTROL INSTINCT will be on the market, I think next month, is too early now ;)
geposted Mon 18 Jun 12 @ 5:15 am
I can't download your pack it says you license don't let you download this
geposted Tue 21 Aug 12 @ 12:57 am
The download is limited to users with registered Professional Full version only - because you can use the download with none of the other versions of our Software.
Greets, Heiko
Greets, Heiko
geposted Tue 21 Aug 12 @ 1:01 am
