Hello. I recently upgraded my controller from a Hercules RMX to a Denon DN-MC6000. When I purchased the RMX it came with a home version of VDJ, which I upgraded to VDJ Pro. The Denon controller also came with VDJ LE.
My question is, is the version of VDJ that I am currently using compatible with the Denon controller or do I need to install and register the version of VDJ which came with the Denon controller? If I install the new VDJ disc that came with the Denon controller, it has a different product key than the Pro version i am currently using. Will my current Pro subscription allow me to update the LE version with the new product key to VDJ Pro? I think I'm ok to continue with the currently-installed version. Just looking for some advice.
Thx!
Thx!
geposted Mon 18 Jun 12 @ 8:52 pm
The PRO FULL version is all you need from now on. Just download and install the newest version located in your download center.
geposted Mon 18 Jun 12 @ 8:56 pm
Thanks! I thought so. Just wanted to make sure.
I've been using my original Pro Full version, but have been having some minor performance issues. I guess I have some other problems. I'll address them in the Mac Forum
geposted Mon 18 Jun 12 @ 9:02 pm
