Hey all,
I've been given a CDJ-100 and a DJTech deck which I now have bought a Behringer NOX404 USB mixer for. I've connected the Decks using RCA cables to the mixers phono connections and the USB cable to my Macbook with VDJ 7 Pro with the following sound setup
Inputs: None
Outputs: External Mixer
Soundcard: USB Audio CODEC
This allows me to play songs on one channel (Channel one which is very annoying) through the mixer but doesnt load onto my decks as I'd expect this solution to do. What am I doing wrong here?
Kind regards,
Erik
Inputs: None
Kind regards,
Erik
geposted Wed 20 Jun 12 @ 10:00 pm
So Figured out that the NOX404 only supports USB through one channel :DOH. Guess I need to buy a external soundcard to get this to work. Any tips on this? And would buying a external sound card allow me to use the decks in playing and cueing the songs in VDJ? Currently I cant even use the CDJ-100 to play/cue on the line 1 thats playing..
geposted Wed 20 Jun 12 @ 10:20 pm
