See if u are using an external mixer with virtual dj. What should the master be set at on virtual dj so i don't go breaking my speakers
geposted Thu 21 Jun 12 @ 4:12 pm
If you're going to feed the VDJ output into a mixer, then you need to check the incoming level on the VU meter for the mixer channel that you have the computer output plugged into.
Set the level using the gain control on the mixer for that same channel, so that the level is around 0dB (in the green) and not making any red lights come on - this is exactly the same as you would do for any other type of input to the mixer.....CD, vinyl, tape, whatever.
geposted Thu 21 Jun 12 @ 4:42 pm
