Okay, here is the situation. I'm using the Gemini CDJ700 in midi mode, and every time I press play either on deck A or B, there is a small delay, I will say about a second delay from the moment I press play to the time the songs starts to actually play. I tried both on vinyl mode and regular CDJ mode and I still noticed the delay which really sucks when beat matching.
However, when I use the CDJ's with an USB thumb-drive, I don't experience any delay. As soon as I press play, the music starts automatically, both on vinyl or regular CDJ mode. Any ideas as to what might cause this small delay when in MIDI mode?
geposted Sat 23 Jun 12 @ 12:35 am
plug it into midi trace and see if it's a hardware fault or limitation.
https://virtualdj.com/download/miditrace.exe
geposted Sat 23 Jun 12 @ 12:46 am
Got it, this is what I get.
geposted Sat 23 Jun 12 @ 1:21 am
just one of them at a time
geposted Sat 23 Jun 12 @ 1:23 am
oh, let me do it again.
geposted Sat 23 Jun 12 @ 1:26 am
okay, I just did each individually, and it's the same thing.
geposted Sat 23 Jun 12 @ 1:29 am
you need to choose the in and out
geposted Sat 23 Jun 12 @ 1:48 am
what do you mean, I don't understand
geposted Sat 23 Jun 12 @ 1:49 am
on the right
geposted Sat 23 Jun 12 @ 1:52 am
Got it, this is what I get, can you help me decode it?
It's the same thing for both units.
geposted Sat 23 Jun 12 @ 1:54 am
does it send the big line then the small one every time meaning you pressed the play button twice? that's sysex which I know nothing about, you might need to contact cstoll or hieko if that's the case.
geposted Sat 23 Jun 12 @ 2:00 am
got it, okay I will contact them. Thank you for all of your help.
geposted Sat 23 Jun 12 @ 2:03 am
